Nice cam. Slightly stouter than my streeter above it.
A SFT I assume.
A SFT I assume.
A SFT I assume.
AJ...just because I hate math (I can do it, but I hate it's) would mind working up the numbers for my combo? What does the math say???
Hey AJ! Do mine! .030/360 @ 10.81-1 ratio.
(Oh, adjust valve lift for 1.6 rockers.)
Lunati cam card above.
No, like the cam card below.
Thank you AJ! I appreciate it.Oh sure make me go hunt for it and slow me done yet more,lol.
OK, working on it
OK, working on it
I made no compensation for the changed R-ratio
Ok so firstly the card doesn't say that the advertised is after lashing, but I assumed it was, cuz it sorta works out pretty close. So if that is true, them: I get
279/285/110+4/62 overlap/114.5 comp/103.5 extraction/ Ica of 65.5 compared to
YRs combo at
283/283/105+2/73 overlap/ 115.5 comp/111.5 extraction/ Ica of 64.5*
Notice YRs overlap is plus 11*, and that is power right there. Your compression is about the same, but again, the 110LSA has robbed degrees from the extraction, and your fuel-economy will be right down there with mine.
Ok lets install it
Static compression ratio of 10.81:1.
Ica of 65.5 and 500ft elevation,365 cubes
Effective stroke is 2.75 inches.
Your dynamic compression ratio is 8.54:1 .
Your dynamic cranking pressure is 175.38 PSI. ................... 175
V/P (Volume to Pressure Index) is 148 ............................... 148
Excellent street brawler
Now lets see what happens with the LSA closed up to 105; I get
279/285/105+1/72 overlap/116.5 comp/111.5 extraction/ Ica of 63.5, again compared to YRs
and installed
Static compression ratio of 10.81 rumble:1.
Effective stroke is 2.80 inches.
Your dynamic compression ratio is 8.67:1 .
Your dynamic cranking pressure is 178.90 PSI. ........................ 179
V/P (Volume to Pressure Index) is 153 ................................... 153
Whoaa, that's a lotta lotta VP! but notice the extraction has picked back up, and perhaps more importantly, the Overlap has jumped up 10* bringing with it a nice power surprise, if the headers don't have to work into a restrictive exhaust.
Bada boom
But I gotta ask; with a starter gear of 2.66x4.10=10.91,
Like my 3.09x3.55=10.97
How are you planning to make that killer VP stick?
Your cam lists the Advertised already at .018 lash, so what you see is what you get
but check this out;
283/283/105+2/ 115.5 compression/111.5 extraction/ with an Ica of 64.5.. This is exactly what I was thinking about!, when I posted #40..
In your stock 340, this works out to
Static compression ratio of 11.02:1.
Ica of 64.5, and guessing at least 500 ft in Razor's Edge, 340 cubes
Effective stroke is 2.56 inches.
Your dynamic compression ratio is 8.74:1 .
Your dynamic cranking pressure is 180.79 PSI............................... 181
V/P (Volume to Pressure Index) is 142 .........................................142VP
This would be a dynomite anything engine, with waaay too much bottom end for the street, being very near to same as mine.
see below
AJs combo; corrected to 500ft
Static compression ratio of 10.95:1.
Ica of 64*, 500 ft elevation, 367 cubes
Effective stroke is 2.79 inches.
Your dynamic compression ratio is 8.75:1 .
Your dynamic cranking pressure is 181.07 PSI. ............................. 181
V/P (Volume to Pressure Index) is 155 ......................................... 155VP
but the cam in mine is a hydro, and the advertised is at .008 tappet; and the spec on it is
276/286/110+4/61 overlap. but the actual valve closed to valve closed could be more like
288/298 ( could be even more, I never checked) and that changes the overlap to 78* where the valves are actually closed like yours are with the solids, and that moves the Ica to 70* and the new Wallace is;
367 cubes, Ica of 70*, still 500ft
Effective stroke is 2.64 inches.
Your dynamic compression ratio is 8.34:1 .
Your dynamic cranking pressure is 169.98 PSI. ................................. 170
V/P (Volume to Pressure Index) is 138 ............................................. 138
To compare the events then, my hydro;seat closed to seat closed, could be;
288/298/110+4/78 overlap /110 comp/102 extraction/Ica of 70*... compared to your solid at
Notice your effective stroke 2.56 compared to my 2.64; practically identical. And our bores are both 4.04. Also Notice your
115.5* compression, with the earlier Ica, is making 181psi/142 VP compared to mine at
110* compression, with just 4* later Ica is making 170psi/138 VP; the VPs, what counts on the street, being very similar.
But look at the extraction, yours is 111.5, compared to mine at 102. And I gotta tell-ya mine is a real pig for gas mileage.
I like your cam choice. It's everything mine is,and more, (we never talked about the tighter LSA) (nor your .620 lift compared to my .549/.571), BUT; without the horrendous (lol) fuel economy penalty.
I'm done with hydros.
I hope that makes sense
Oh! You edited the post. Almost missed it.
“Excellent Street Brawler” was the goal, thank you.
The exhaust is 1-3/4 Hooker Super Comps. It has a close to a zero loss exhaust system even though it is full length. It’s quite effective.
Backed by a 833 4 spd. & a 4.10 ratio.
Our stuff is very close. I have a 833 with a 4.56 and my box is a 3.09 low gear.
And I have 1.875 headers, Strip Dominator.
Agreed. I was entertaining the next larger Lunati SR but figure to error smaller. The car is heavy-ish @ 3465 as delivered. Besides aluminum on the engine, it has a AAR fiberglass hood. Also thought about 4.30’s but decided to skip the expense. The engine should rpm well even for a off the shelf cam. Nothing to hairy. The ported Edelbrock heads should carry the cams range a little further. I think it should be a good all around pump gas mill that can travel a bit.
Those 1.875 headers are Hookers? Outside diameter?
I thought I did, but I was wrong!!!!!!!
cause ya ant sposed to be trying to make power with a lowly 318 to start with!! sposed start with at least a 360 if not a 340 if you want that real mopar power! lolololYou coulda had another 50-60 HP if you used those 302 heads as dump filler. Why give up power? I just don't get it.
Do you think it has more to deal with people pick cams base on duration ?
I get most of us can’t pick on opening and closing points, so we go with duration lsa and overlap.
But most don’t even consider overlap except in a intuitive way.
Eg.. like if you picked a cam for a 3.23 geared 318 in a B body and went with 286 cause your eyes were bigger than your belly.
And knowing it’s probably too much went with a 114 lsa intuitively going with a 58 degrees of overlap.
Instead of deciding of starting with a decision of going with 58 degrees on something like a 105 lsa to give you 268 cam which is probably closer to acceptable ?
