I recently cam across an almost brand new Bullet solid roller cam for sale for $150. I would not have considered used under other circumstances, however cam looks to be like new and is similar in spec to what I was thinking of using in next engine. The application is race only, 372ci, w2 or Indy 360-2 heads, r3 block, compression around 12.5, and solid roller cam, pro dominator tunnel ram, 2 Quick Fuel 750's.
I have attached cam card to show grind. My concern lies with the longer duration on exhaust, I would prefer a single pattern or much smaller split on duration while using heads with a very good exhaust port. Could the exhaust duration be reduced much with regrind? Today I will be calling Bullet and Oregon cams for info, just looking to get info and experiences from FABO friends as well. Thanks everyone.
