twayne24365
Well going to pull the motor out of dads car, currently
10:1 .030 over 440
440 source rotating assembly
CNC stealth heads
Hughes .626 lift 254@50 solid
Victor with 850 Holley
Only had it at the track once and ran 7.32@94 1/8
The rear main leaks so going to replace that, mill heads .030 and smaller gasket for 11:1
Going with comp .650 solid roller with lifters and springs
Swapping 440 source rockers for most likely Hughes rockers
And port match the intake as well
Car is 3500lb with 4:56 gears and 5000-5200 converter.
What do you think the gains will be?
10:1 .030 over 440
CNC stealth heads
