mderoy340
I'm degreeing my cam and it is 4* retarded when installed straight up. I can only advance the cam 2* at the crank with the timing set I have.
Anyone know approximately how many degrees timing changes by advancing one sprocket tooth at the cam?
I do have an offset cam key set but if I can bump the cam sprocket and get the needed 4* I will.
Thanks for any info.
