edbux
Let's say a friend....installed his cam with a centerline of 106 degrees with the crank sprocket on the timing chain 4 degrees advanced. Would this mess with
the timing? ie the 16 degree initial timing for the distributor when set actually be less?
The answer to this "hypothetical" question for a "friend" is appreciated.
