charger426
Its been a bit sine I was out adjusting my upper control arms on the Dart. Any reason why something like this wouldn't work with the tabs the current eccentric bolts use? Would have to be the right size to fit into them for sure but I have a set of these on the shelf right now for the ACR and was thinking it wouldnt be hard to do a quick design in CAD and have some laser cut.
OOOOORRRRR would this be a big waste of time as the Abody's dont have the same issues as the vipers when you autox or more particularly road race them and use the curbs. Vipers are known to loose their alignment after a track day or two.
Shim Kit - Comp Coupe Dodge Viper - Viper Parts USA
Shims must be used with either our Camber shim bolt Kit ( 271 406 000 00) or our Stud kit (220 406 101 00). Fits All Year Dodge Vipers Competition Coupes
www.viperpartsusa.com
