500 threads about 318 cams and still no one can recommend an off the shelf "next step up" cam for a 318 with only a 4 barrel and dual exhaust as mods that doesn't have a power band that starts well after the normal street operating range.
Waiting for you to step up with a recommendation.500 threads about 318 cams and still no one can recommend an off the shelf "next step up" cam for a 318 with only a 4 barrel and dual exhaust as mods that doesn't have a power band that starts well after the normal street operating range.
Comp Cams XE-256500 threads about 318 cams and still no one can recommend an off the shelf "next step up" cam for a 318 with only a 4 barrel and dual exhaust as mods that doesn't have a power band that starts well after the normal street operating range.
Just never heard of .520 as being the accepted max lift before having to cut down the guide bosses? Could be. Variables I was referring to are spring retainers used, keepers used, suggested ( by the cam Mfg.) spring installed height, new guide installation height. At any rate, I didn't have a clearance problem with my set up.
For what it's worth, i got a 72 Demon this summer. It has a mild built 318 consisting of stock bottom end and cylinder heads. It has headers, duel exhaust, and edelbrock performer package. This is the performer manifold (not rpm air gap) 600 cfm. carb. jetted of economy (1406) and their small performer cam, like 204* duration and .420 ish. lift. Car ran best of 15.4 seconds at Earlville this summer with 904 trans. and 2.76 open diff. a very nice running streeter. 17-18 mpg. But boy is that going to change!!
Thanks. Bookmarked.Hydraulic Flat Tappet | Jones Cams
bottom of the first list
H440D64307
H440D is obvious
64 is 1/4 of the duration =256
307 is the lobe lift
what is interesting if you cam doc this cam compared to other 256 @.006 grinds is that it gets shorter at .004 (compare .004 with a Crane .004) and way much shorter @.002
and is still big or bigger at .200
It is 50% larger than the DC 260 cam at .275
has a big nose- not a pointy cam designed to show off max lift
Asymmetrical and easy on the close for no bounce
Yes, very good numbers for that combo - and I am sure a fun streeter to drive. Pic is checking installed spring height on Magnum heads going on my 318 in my 74 Duster. Seals installed, and clearance to bottom of retainers was checked next with "light" checking springs, both on intake and exhaust. I might ad that 7 of the 8 chambers on these heads were cracked between the valves ( typical for Magnum motors of this vintage - 1996). Had stellite seats put in which solved the problem. No coolant leaks.I have read that about Magnum heads.
Not bad numbers. Ever run at Cedar Falls?
Welcome to FABO Daniel. If your 66 has the original engine it will be a 273. 318's weren't available in Darts until 1968. 273's also had solid lifter cams and you can convert a 273 to hydraulic with the right parts to go with it.Read tons of pages here and there, but so much info and opinions I'm getting confused, especially for my application.
Have a 66 dart with a stock 318 (only have dual exhaust) 2 bbl carter and stock iron intake. Want to get more fun driving it but thinking of more of low end torque than high end RMP (Don´t think I'm going to exceed 5.000 RPM at all).
I'm planing a cam switch as a first upgrade, definitely want a 4bbl later but will have to wait at least a year. My dilemma is if there's a way of gaining power only with a cam switch? Have these in mind:
Summit Racing® Classic Cam and Lifter Kits SUM-K6900
Summit Racing® Cam Kits SUM-K50052
Leaning towards k50052 but don't know if I'm going to actually loose power. I'll be OK if I just pick up 5 HP and be ready for the later 4bbl swap.
Any advice?
You're good then.Thanks, it's actually a 318. The car originally had the Slant 6 but I did put the 318 in.
You're good then.
Sounds like a cam swap and a 4 barrel intake would be a good time to do both. You will have the intake off for either project. Good that you have dual exhaust already. Just don't over cam or you will be chasing your tail trying to make it all work by adding high stall converters and steep rear gears. And no sense in performance cam when using a 2 barrel. The Jones cam the guys talk about in previous posts sounds like a good one. It is designed for what you are doing. I have a 2 barrel 318 in my Swinger that I have plans to upgrade. Thinking serious about that cam. I have a LD4B intake and a 650 AVS2 and 340 manifolds for my dual exhaust.Read tons of pages here and there, but so much info and opinions I'm getting confused, especially for my application.
Any advice?
The K6900 is the milder of the two. It would be my choice.Are you saying I'm good with any of those cams?
Forgot to say my 318 is from 1975 so I guess is a low compression engine.
