camshaft for mild 340
Unmilled J heads will take .040 to get to minimum. So, IF unmilled heads, then that puts the chambers around 73cc. Since you have 10.5 340 pistons, that will get you close enough for picking the right cam. I just ordered a solid cam for my low compression 340 from Racer Brown. Call a couple cam manufacturers and get their input.
I’m running a summit can that’s a step or two above a stock 340 cam. You would probably really like it. I have the number at home but won’t be home till tomorrow night.
Ok was able to grab it from my phone.
rumb
I never said assume low compression
I said if he did have a later 340 then you go one way
with his build he has a lot more choices
The 268 comp is short for the amount of lift- go voodoo instad, or howard, or Bullet, or custom Engle, Crower etc
the summit can be had cheaper as an Elgin yet another chevy regrind
the DC cam is fine but obsolete and pricey
That summit cam is REALLY close to the old 280/480 mopar camshaft. It's cut on a little wider LSA 112 vs 110 IIRC
Another inexpensive camshaft that works well is the old 214/224 cam. Faster lift stuff is nice but also has greater potential for failure and other parts not playing nice.
Pick your parts, pay your money!
Same reason why I recommended the intermediate priced grind I did. Not a super fast rate, but not slow either, card spec matches the rest of the OP's combo nicely, a little more "lope' at idle but still have excellent street manners. Sure there is more power on the table, but this choice should still play with all the other components nicely and have very good street manners.
rumb
Read below.
No you didn’t.
Pricey yes, obsolete? What is obsolete about what works?
Wyrmrider ....
stock 340 cam in low compression motor leaves a lot on the table without converter and gears
Oh never mind!
Comp Cams 268AH-10
It's basically a stock 340 cam with a more modern split grind. I love it in my 360. It's 9.4:1cr with 1.88/1.60 Jheads.
Hey vntned! So off topic but really want to know what wheels are on the dart? Also if you don't mind dimensions like backspace frobt and back.
Those were Cragar Eliminator 500 wheels. 17x7s up front and 17x8s in the back. Off set has slipped my mind currently. You might be able to search my old posts and find the info.
garret et al
check the .200 duration of the Summit, 268 and 270 comp, 214/224 etc and compare with the DC you end up with a lot of duration for the area under the curve= power
The 284 DC checking at .008 is a lot bigger than the 284 Summit checked at .004 compare apples and oranges
COmp 268 (checking at .006) is way too expensive for what you get as is the DC
the mild .904 cam grinders I mentioned are actually less radical than the 268 comp which at its time was pushing the envelope for a chevy grind
yes rumble obsolete
designed back when jerk was not considered by the big grinders except by Crane the newer designed with a modern computer instead of a hand calculator or first generation computer that Harold Berkshire used are a lot smoother and easier on the valvetrain
Exactly! Slow, reliable ramps have their place!
I got news for all yall. You can say this and that is obsolete all you want. Pick a recipe out of the MP engine book. Any of them. Use the cam they have chosen with all the other parts in the recipe. The engine will run the number. Obsolete? I think not.
a slow reliable .904 grind will wipe a slow reliable .842 grind
IT takes a fast .842 grind to stay with a moderate .904 grind like the MPs
50 year old designs gimme a break
Sure use all the parts in the MP books, now where do you get the gas
Never said they were the best of the best. I said they still work and they do.
...and none of the MP grinds are 50 year old designs. They were all reworked in the 1980s to take more advantage of the .903 lifter diameter. Yes, it's been a while, but that is a fact.
I know that there is more than one car that runs 11's with that dinky 214/224 cam, stock rockers, in 360's with well ported J style heads and a great chassis.
.904 or not, you can make good power and be easy on parts with any number of combinations. Not everything has to be used to the optimal level.
Key word in the OP... MILD!!!!
Make what you got work. There are good grinds out there, choose one and go with it.
Your asking people to compare and search for these things that they never thought of before in an effort to support your position in splitting hairs to prove that you are right. I agree but also stand by what I always say.
I just find it crazy and pathetic that every build you comment require a designated 904 cam. The power difference is insanely small for f even available in low power builds. You know what I mean.
yes rumble, obsolete
Obsolete as in it doesn’t work anymore.
Give me a break!
Come on man, stop splitting hairs.
Mike Beck did just that with a, as wyrm would say, a slow lazy ramp Crane cam of very similar specs, over 10 years ago.
the 214-224 is 50 years old and the Cam Dynamics> Crane Summit- if that is what they use is almost that old
Obsolete as in you can do much better today
power difference may be small but torque is much better
I've used lots of the 204-214 and 214-224 back in the day but not now
yep key word is MILD
I can run 10 degrees shorter with a MOPAR cam with the same pull
Scroll to the bottom of the above linked page.
What I like about this is the in general build perameters, except the missing duration @ .050, and it's reasonable power output while maintaining good drive abilty with the wider centerline cams.
Thisis good everyday streeter tips.
Computer simulations show what happens when we increase compression, add duration in different combinations and then adjust lobe centers using a hypothetical Chevrolet 350 engine assembled with different combinations of compression, camshafts and valve timing as a base.
Stage 1 Base Engine Analysis
Typical low performance: Standard 1.94 and 1.50 valves with typical port flow, OE dual plane 4bbl intake, OE exhaust manifolds and single exhaust.
page4image6480
Static Compression Intake Duration Exhaust Duration Lobe Centers
Fuel
Stage 2
8.25:1
250 Degrees 260 Degrees 110 Degrees 87 Octane
Volumetric Efficiency Torque/RPM
HP/RPM
Effective Compression Vacuum
Analysis
86.7% 360/3,000 245/4000 7.13:1 20.9 in/Hg
page4image11552
page4image11712
page4image11872
page4image12032
page4image12192
page4image12352
Mild production performance: Standard 1.94 and 1.50 valves with typical port flow, OE dual plane 4bbl intake, OE exhaust manifolds and dual exhaust.
Fuel
Stage 3
9.25:1
260 Degrees 270 Degrees 112 Degrees 87 Octane
HP/RPM
Analysis
87.2% 373/3,000 268/4,500 7.61:1 21.1 in/Hg
page4image18960
page4image19120
page4image19280
page4image19440
page4image19600
page4image19760
Performance engine: Larger 2.02 and 1.60 valves and mild porting, single plane aftermarket intake and 1-5/8 x 36 in. headers with low restriction mufflers. With the increased effective compression and volumetric efficiency, premium fuel is recommended.
Fuel
10.0:1
288 Degrees 288 Degrees 114 Degrees 91 Octane
HP/RPM
94.8% 404/4,500 372/5,500 7.55:1 19.6 in/Hg
page4image26440
page4image26600
page4image26760
page4image26920
page4image27080
NOTE — In all but the last stage, “dual pattern” camshafts with increased exhaust duration were required to achieve 75 percent or better exhaust flow relative to intake. Also, note vacuum was kept within a range of 1.4 in/Hg for all three engines. (Ithink there talking about wide open throttle vacuum readings here.)
My experience has been that the “computer simulations” and “hypothetical” engines, built in the software world........ benefit from wide lsa’s a lot more than(typical street, street/strip, basic racing type) real engines tested on real dynos.
Unless you’re not using headers.
Of course.......YMMV.
No argument there; I think it's more meant to give those who have legitimately no knowledge about the particular subject a basis for understanding how cam timing events can affect an engines behavior...
