JimmyV
MOPAR!!
I Am In The Middle Of Building My 360 Just Got The Camshaft In With The Thrust Plate And Cam Gear I Noticed That My Camshaft Moves Back And Forth Quite A Bit And If I Instal The Oil Pump Drive And Turn It With A Screwdriver The Cam Moves Back And Forth Is This Normal? Did I Forget A Thrust Washer Or Something As Far As I Know All I Have Ever Seen Is Just The Thrust Plate..just Want To Make Sure That It Is Ok...and For And Idea I Can Move It Back And Forth With My Hand Very Easily Will Most Of This Disapear Wiht The Valve Train Instralled..
Help Asap
Help Asap
