earlymopar
Just curious where you guys are installing your camshafts for supercharged street driven small block cars; "straight-up" or other? My cam specs are: 224/224 @ 050”, 270/270 adv, .470”/.470” lift, 112 sep. I'm running 1.6 rockers on the exhaust and 1.5s on the intake so my actual duration and lift on the exhaust side are increased. I just got my short block back from the shop and noticed that they installed my cam 4 degrees retarded (my directions were "straight-up"). I know what this does to valve timing and piston to valve clearance as well as peak torque changing by a couple of hundred RPMs. I've measured the ICL and that came out to 111 degrees. This is a 6 lb. boost set-up (twin screw Magnuson).
-EM
-EM
