camshaft suggestions
lenweiler
Canada
Anyone running high 9's on the engine. What's your camshaft profile? Assuming it's a roller.
I'd be indebted to you if you tried this cam.
Crane Cams #688681
Lift:0.675 int./0.638 exh
Duration at 050 inch Lift:
280 int./288 exh.
114 LSA
Little shy on the lift, but duration @ .050 looks close to what I think I need.
Damn, that's what my new heads flow and your going 10.30's.. Kind of exited right now.
I run 6.20's in the 1/8. The Wallace Racing calculator says my best is 9.82 in the 1/4. My solid roller cam is a custom and is 255/266 @ .050 , 10.9 comp. at 2950 lbs. Pump gas 394 cubic inch.
