Here we go....
This is not purely hypothetical.
Years ago I had a 318 in a Duster that was a S-L-U-G ! I tried all sorts of things to improve it but it was still slow. I pulled the timing cover to find that the cam sprocket and crank sprocket did not line up at the 6:00 firing position. With the crank at 12:00, the cam sprocket was off by at least one tooth.
Here is the question.....How much cam timing is in one tooth?
I realize that you just divide the number of teeth on the sprocket by 360 but which sprocket do you do the math from?
I don't remember the amount of teeth on either sprocket. I'm also curious if the number of teeth is always the same no matter who makes the timing set. It is always a 2 to 1 ratio though since the crank sprocket is 1/2 the size of the cam sprocket.
If the cam sprocket could be rotated ONE tooth to line up to the crank sprocket, that is one thing. In theory, that is 1/2 tooth of timing at the crank, right?
This would mean that the cam sprocket could be off 1/2 of crank timing per cam sprocket with a chart as follows:
1 @ cam = 1/2 crank
2 @ cam = 1 crank
3 @ cam = 1 1/2 crank, etc.
Back to the Duster 318. This was in 2008 and the memory is a bit fuzzy. It was off the mark enough that the engine ran smooth but was gutless no matter how much spark timing was put to it. I tried different intakes, carburetors, distributors and even uncorked the exhaust. Once I put a new timing set in it, (Installed correctly) the car was great. Before, it wouldn't peel out even on light gravel over hard packed dirt.
What say you? What amount of cam timing difference do you see per tooth ?
1 @ cam = 1/2 crank
2 @ cam = 1 crank
