Sorry, when I said domed I was thinking 70 and before. That big a cam with that piston will drive like crap. Even if it even idles under 1200 rpm. Noooo low end at all. Once, i had to get an engine in quick, to go to work on Monday. I grabbed a 73 short block and threw a .484 purple cam in it. Nothing until 3000rpm, smallest p/v made. Doggy.
Threads like this kill me. It's 2 pages of us trying to help and 2 pages of you not listening.
Try this one……. Because you need to over cam once so you know what is being said.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=623&sb=2
The camshaft I'am going with now is a comp cam XE275HL or XE284H. I want a camshaft that has a lope to it.instead of a smooth idle I want low end too. I have 456 gears with a spool and I'am going with a 3500-4000 stall.
The XE275HL definately has both the low end power and the "lope" you're looking for. Its modern design really does give you the best of both.
Sounds good, just to let you know that for my build I was completely open for advice when choosing the cam. My good friend Tim Banning at FHO (For Hemis Only) has been building Mopar engines for years and this is the one he insisted I use. His track record of engine building is now legendary so you can be sure you have made a great choice. I am using this one and am sure glad he suggested it.
Here is his website to check out, you will see what I mean !
http://www.forhemisonly.com/customerpics.html
