nm9stheham
Well sure.... that's how they came up with the classifications of 1/4 Midget, 3/4 Midget, right? LOLHow many degrees is 1/4 dot, 1/2 dot and if I advance 3/4 dot do I have a 3/4 race cam?
Your camshaft choice will be very satisfying. Put them in straight up, your static comp maybe a touch high for a boat and the available fuel on the water. I'd bet your idle vacuum to be somewhere around 16-17" without much difficulty, idling around the docks and outdrive shifting should be a non-issue with a low RPM idle speed you will use. Keep us updated when you dyno them. J.Rob
That cam should idle very nice around the docks. Unless the manufacturer specs and install of 110 I'd go 2 degrees to start. If it idles decent maybe 114 would really suit you better. Is this going on a dyno first?
The GM Vortec marine engines run 9.4 to 1 compression, so that is what I aimed for, making sure I had good .040 quench. Would I be better off going up to a .050 quench and lowering the compression to 9.2? At the fuel docks it's usually 93 and sometimes 89 Octane. I plan on keeping some good Octane boost on board in case it's an issue at unknown docks. I'm running Volvo drives and they use a cone clutch so that should also help with shifting around the docks.
OK....try this one
408 stroker
9.9ish cr
LD340 or RPM intake
Heads undecided but 270+ flow @ .550 with closed chambers
1 5/8 x 3" headers
904 a/t with 2700 stall
3.55s
Power brakes. ( I've run PBs with 8"s of idle vacuum to my satisfaction....)
Mostly street with 3-4 track days per year
I want to go roller (solid or hydraulic)
3600 lb Fastback
Did I leave any vitals out ?
Number one, with that tiny engine the headers aren't too small unless you plan on spending a lot of time over 6,000 rpm. Number two, tough to pick a cam when you don't know what intake manifold and heads (intake and exhaust flows for certain) you are going to run. Oh, bye-the -bye, I'm just asking for the information for others, because I have no intention of designing a cam for you.
Any thoughts on this stick
I'm not seeing the lca Not trying to look like a dumb axx butI would install it at 102 and let it go. If it seemed light on bottom end, put it in at 100.
Just my experience on our dyno testing small block headers on a 423.5 ci LA engine to 6,500 rpm. I realize it wasn't much of an engine as it only made 601 HP on 91 octane.Really? It's 400 plus inches. It needs a 1.875 tube about 30 inches long and the cam to match it. That 1.625 tube is for dead stock stuff or Comp eliminator. There really is no in between.
Intake max lift at 103 degrees after top dead center = 103 ICL. They want it 5 degrees advanced on a 108 LSA. (103 + 113)/2 = 108I couldn't see it either, but if you add the intake centerline and the exhaust centerline together and divide by two you get the LSA. I also didn't see where Crane said to install it, but the late closing LSA could use some advance.
Our custom designed solid roller we had Comp Cams grind for us. It's not one I would call out for power brakes. I design all the cams for the engines we build.What cam were you using ?
There is another thread that was posted and I've linked to it that shows this exact comparison in a members 340. I linked to it in the original thread where the initial disputes of LSA took place.
Keep in mind on what lustle said that the torque itself may not happen at a lower RPM, just the peak HP.
Did I read his question right and your answer right??
You are saying you'll have more low end torque with a 108* LSA and less with a 112* LSA?
His question
Some actual dyno tests changing LSA only...........
http://www.cranecams.com.au/pdfs/MAY14-Lobe_separation_article.pdf
Lobe Separation Angle Explained and How it Affects Horsepower
the 110 LSA cam perform, it is easy to
see why this grind has become such a favorite of aftermarket. (Remember the whole bit about common LSA range?) cam grinders. The balance of midrange torque, idle quality and top-end horsepower seems to lend this cam to the majority of street/strip engines.
This LSA is a great middle-of-the-road cam that offers a taste of both worlds.
It also made peak HP.
