How do i go about that is it imprinted in there? Or is there a special way to check.
Its an 8-3/4 rear with a 741 case.....To check ratio, easiest way is put a mark on the drive shaft and a mark on the tire.....jack up rear wheels if sure-grip and spin tire one revolution and watch how many times drive shaft spins....3-1/2 time is 3:55 , 3-1/4 turns in 3:21....etc. etc...If you jack it up with both wheels off the ground and the one tire spins in the opposite direction when you turn it, it is an open rear.....And you can still check it to see what gears on in the rear by using the same method as described above, however one tire must be on the ground when checking.....So only have one tire in the air....
Yup...it's stamped into the ring gear, along with the part number, date code,etc......
Gears are interchangeable, 741 is decent for "light/light" (weight/horsepower) platform, tapered axles are no good. Supposedly if the drain plug is painted its a SG (myth?) may still have a ratio tag on a bolt?
What are my other options using 8 3/4.? Other than the 741?
*742 and *489...1 3/4" straight stem and 1 7/8" tapered stem respectfully.
I didn't know it was that easy thanks but unfortunately this truck is jacked up on welded on to some old rim stands is there an alternative way to check? I know there limited slip I'm hoping there 3.55 or up. ( I wish they were posi but there not)
Another way that works, especially if the ring gear doesn't have the ratio stamped on it, is to divide the amount of teeth on the ring gear by the amount of teeth on the pinion gear.....that also tells you the ratio, unfortunately you have to pull the chunk out to see that also....
