Can anyone help me find the replacement bushing
memike
Super Moderator
Staff member
on the hill
Looking for a supplier for the sway bar bushings for my 66 barracuda sway bar, no luck at all on
my search, my tech said he can change them :glasses7: but I have hit a road block on locating a pair :banghead: well any help on this sure would be cool :glasses7:
Those square bushings were repoped then sold out ( n/a ) for quite a while, and them repoped and available again. All this occurred about 5 years ago so they may be n/a once again. If all else fails you could just buy a block of material and make them.
Simple in design at least. Good luck
Thank you RedFish, The bushings that are there seems to be nice and not dry rotted :glasses7:
But my tech said if I can get a set he could replace them.. I may just run them in hopes to find a set down the road, or go with a repop sway bar attaching mount I have seen :coffee2:
Thank you very much for you time RedFish :thumleft:
memike...seems to me I saw those or ones just like them at a pepboys speed shop. I only remember them because I said to myself that now I know where to find them when I need them.
If there's one close by you.
Thank you very much 67dartgtgo :cheers: well worth looking :glasses7: Thank you :thumleft:
Bet they got them and you can talk to them on the phone.http://chucker54.stores.yahoo.net/swaybarbus.html Looks like the ones at the b0ttom
Looks like I need to call and get an inner diameter size Pete :wave: :thumleft:
