timk225
I'm working on my 1973 Duster (electronic ignition) and I'm taking apart the distributor to clean and regrease it all. Even though it seems to work when I unplug and reconnect the vacuum line and watch the timing with a timing light, I want to replace the vacuum advance module, because it is probably original, and if it hasn't started leaking already, it will with more regular use. Anyone know where I can find one? The numbers on the advance arm appear to say "8.5 R", so I think that is 17 degrees at the crankshaft of spark advance.
I was on the Advance Auto Parts website and saw a replacement Carquest /6 distributor with a cap and rotor for $83, is that my easiest option or something to avoid?
What would be a good amount of total advance to use on a stock to near stock 225 with 1 bbl Holley and a 904 automatic? Years ago I ran around 4-6 degrees initial advance, and I forget what my total timing numbers were.
