Can I get a nut? (Pitman arm nut...)
Sulring
Member
Lacey, WA
My Pitman arm nut went missing.... anyone have the size/thread/pitch on a 1965 Barracuda, manual steering V8, auto if it matters?
Thank you
Bryan
The nut that holds the pitman arm to the pitman shaft or the nut that holds the centerlink to the pitman arm?
If so, it's a 1/2-20 just like the idler arm, tie rod ends, and BBP lug nuts. Get a castleated grade 8 nut and the proper diameter cotter pin.
