can someone help decode fender tag?
discharger1332
silverdale wa.
FE5 U N95 R11 Y14 END
FE5 M1XX TX9 A22 074678
E24 D13 LL29 C1E 116886
in need of a little help, thanx in advance.
appears to be a rallye red body and roof (FE5) /6 (E24) 3spd (D13) demon with black interior (M1XX TX9) with a standard AM radio (R11) i almost want to say the N95 is hood pins but not for sure as im doing this from memory and not a book the Y14 would be a shipping code and im lost on the A22
Here you go
Code
Description
E24
225 1 Barrel 6 Cyllinder
D13
3-Speed Manual Transmission Floor
LL29
L = Dodge Dart / Demon
L = Low
29 = 2 Door Sports Hardtop
C1E
C = 225 145HP 1-1BBL 6 CYL
1 = 1971
E = Los Angeles, CA, USA
116886
Sequence Number '116886'
FE5
Paint Code: Bright Red / Rally Red
M1XX
Trim Grade/Style/Color
M = Medium
1 = Cloth and Vinyl Bench
X = Black
TX9
Upper Door Frame: Black / Black Velvet
A22
Date Built: 10 / 22 / 1970
07467
Order Number: 07467
FE5
Roof Type OR Color: Bright Red / Rally Red
U
Built to Specifications for USA Order
N95
Emissions Control
R11
Music Master Radio AM
Y14
Sold Car 69-71
END
End of Codes
LL29:
Dodge Dart,Demon
Low
C1E: 225 145HP 1-1BBL 6 CYL
1971
116886: Sequence number
E24: 225 cid 1 barrel 6 Cylinder 145hp
D13: 3 Speed Manual Transmission-Floor Shift
FE5: Bright Red Exterior Color
M1XX: Trim - Opt. Decor Group, Unknown, White/Black
TX9: Black Int. Door Frames
A22: Build Date: October 22
074678: Order number
FE5: Bright Red Top Color
U: USA Specifications
N95: Emissions Control
R11: Radio Solid State AM (2 Watts)
Y14: Sold Car
END: End of Sales Codes
A22 is probably the date code, which would be a scheduled production date of October 22.
N95 may be emission controls, at least it was later on.
Edit: Everyone else types faster than me!
thank you, i couldnt figure m1xx. pretty early build date huh. not many options, looks like it could be a good one.
thanx again
