wheelman21
Mopar noob
Sounds like a Comp Cams 284 duration cam....
Also, props to Kuda, the specs on that cam are very close the 508 cam that I believe I have. Nice work.
It sounds pretty stout, especially at that rpm. It may very well be a .508" purple, as i have been around several. I'm real curious to what your initial timing is? Anything 12* or under will make a lot of cams in that range sound big...
Ok so I did some digging through my notes. I came across a couple of numbers. The big one is 509. I know there were some books mentioning a MP 508 and 509 cam that were pretty nasty. The 508 is listed at 248.5* of duration @ .050" lift ground on a 108 LSA. Is it possible that's what I have? The guy I bought it from called it a 509 cam, but the 509 for the small block was a circle track cam from what I remember reading and pretty rare. From what I've read the 508 is a pretty nasty cam.
I ran a 508 mopar stick for years that cam is a race grind and should be matched with a 4 speed and no power brakes ...I ran it on the street and think it had about 11 lbs vacuum
3/4 race....i can hear it skip a beat....
