greymouser7
Vagrant Vagabond “Veni Vidi Vici”
- Joined
- Apr 17, 2010
- Messages
- 3,729
- Reaction score
- 1,457
My 69 year old uncle is a 'sugar daddy' to a 31 year young lady. Never mind that!
He set her up with a business on her grandmother's property selling trailers. (She also works at a Toyota plant)
You know some times I think am smart or stupid and then I get a reality check working with others. There are some beacons of sunshine and dark pits of hella stupid...
I work my way past 'why this girl hasn't done any of this leg work' {hella...} and (as requested) dive head first to help a friend of the family, i guess...
7 wire set up,
two derelict pickups which NEITHER have working trailer plugs/outlets/connections working...
have to bring the 6 year old daughter with me while the wife works-of course she gets bored so I am also keeping an eye open watching to keep her safe,
this grandmother's single wide mobile home trailer is F I L T H Y (still has her 3month passed on grandmother's dentures in the bathroom,
I DO have good trailers to reference,
I had a single sheet copy diagram of wiring schematic for the connector ( I assumed was accurate, but Noooo),
girl got off of her shift at 06:00 AM, is tired and cranky (no biggie, i worked in a pipe full of asset holes right!) and I got done helping OTHER family at midnight last night,
i get me and the 6 year old ready, feed 2 cats, dog, feed/clean 2, two week old kittens and head out
dig for my multimeters, extension cords, surge protector, battery charger as a verified 12 volt source, wire strippers, test light, buy some supplies,
get there and trailer has a connector with 8 wires and 6 connectors
wires are not the color of the designation of the connector
I disconnect the two tail lights of the OLD RUSTY trailer, clean the contacts, check the bulbs, check the grounds and then commence checking continuity on the tail light wiring
Brown wire is the running lights
yellow is brake/blinker for one side, green the other side
white is a ground, blue is brakes,
there is black wire labeled battery for a break away system that engages brakes with a fist size battery tied into what i guess is a solenoid that engages the drum brakes when the trailer miraculously falls off the truck - i think it charges with the running lights
bad trailer has TWO green wires, one is a ground besides white-eventually figured that out and tied them together into the connector's harness
bad trailer has a different black wire and a second white wire
good trailer has 2 whites, 2 blacks, 1 brown, 1 yellow, no green
Neither trailer matches the diagram (which as a brainwashed MT, the documentation was always our HOLY reference point and NEVER questioned on the big bombed SLBM's)
good trailer is verified good after i convince the young lady to let me take the truck to the auto parts store and check/verify all the fuses -one fuse missing, one blown, truck now good-it took over an hour to convince her to do this -NOW I have a reliable power source to check a completed connector (all wired back up)
the male/trailer connector on the old, rusty trailer is warped, chewed up and I easily mix up top from bottom which are slotted for installing on the truck -so I wired the crappy trailer for the diagram, no bueno,..
wire up the crappy trailer connector like the good trailer, no bueno, reverse top to bottom reference with crappy connector
BINGO! We are now progressing...
grounds are ****, i am not quite seeing double in the heat but am second guessing my name and all perceptions...do i have enough grounds, do i have not enough grounds:
running lights check, but weak, weaker on the drivers side
blinkers check SAME but weak on drivers side
running lights on -some times the left (inside the taillight plastic assembly) running light blinks, sometimes the top, or bottom, or both of the TWO filaments of the tail light bulb blink
running lights off, left blinker works great
clean, clean, wire wheel fresh metal where grounds are, all over
it gets better, then it gets worse
introducing the running lights into the circuit re routes where the electricity is flowin through the bulb
connect the trailer onto the hitch on the pickup for more ground - right side is brighter,
left side is still hella dim
am gonna run extra wire tomorrow, but ALL IDEAS are GREATLY APPRECIATED! thank you!
despite seeming intelligent in this slew of writing, I am a noob, and am fumbling my way thru what some of you guys solve in minutes, lots of frustration
7 wire set up,
