I replaced the fuel tank in my Demon because the tank was absolutely filthy with rust and other crud.
Problem is, when I go to the pump to fill up, the tank will only accept 8-9 gallons. I try to get more in, but the nozzle clicks off when I squeeze the handle.
The tank is the same size as the one it replaced.
I installed everything to the way it was before removal(to the best of my knowledge).
The evap. stuff was long gone when I got the car, so the vent tube from the fuel sending unit is open, and not hooked to anything if that makes a difference.
What possible screw-ups could I make to cause this? Any advice is appreciated.
