Hey all, I've been trying to get my project car sorted out, one of the problems I'm having is that after I get the engine warmed up the idle will jump all over the place!
Here's what I got:
It's a 340 with J heads, RPM intake, an Edelbrock 750, and stock electronic ignition with a vacuum advance.
I don't know much about the motor. I got a great deal on it, it runs great (when not at idling) and it has good oil pressure and compression.
The previous owner told me it has hydraulic cam (it has a pretty good lick to it and driving down the road it really wakes up at around 3K rpm), and it also has a high stall converter.
I set the timing to 30 total advance @ about 2K rpm. all I could figure is that distributor might have issue, or maybe the vacuum advance may be the culprit?
I have never have dealt with a motor this wild before and I could use some advice.
Here's what I got:
