dustermaniac
Senior Member
I am changing out the stock distributor on my engine and I have a question. The new distributor which is a CDI unit has a longer blade end than the stock distributor. I can remove the stock one and out and put it back in and twist it and it seats down fine but I cannot get the new distributor to seat down properly. It will line up with the slot in the oil pump shaft and even if I try to twist it and get it to drop in it seems as though the blade end is to long vs the stock end which is very short Note pics.
1st pic is of new distributor. 2nd pic is of stock distributor.
