whatadish
Member
just started totally rebuilt slanty yesterday...sounds great runs awesome but can not get the idle speed down. Easy to see throttle plate is closed all the way...new 1920 anyway. not a choke, timing. or vacuum leak issue either. It is a little too quiet for me in terms of valve lash. Although the machine shop set the cold lash at the shop, could too tight of a lash cause this issue. Petronic breakerless setup, just about everything is new. There was a similar thread on the slant6 forum that did not answer the question of too tight valve lash causing this issue. Once again this is not a carb or linkage issue, choke step plate is off and the throttle plate is completely closed...excellent steady vacuum as well. Any suggestions would be greatly appreciated. Yep there is some pics of the car in my gallery.
