Yote
Yote
I did the same on my home made ramps, welded a piece of 1 X 1 angle iron (with the corner sticking up) to keep the car from accidentally rolling backwards.Good idea, I like the removable ramp part, might consider a small maybe 1/2" piece of square tubing at the edge of the removable part.
I had a car roll down a set of ramps one time in a clutch change, it had been sitting there for a couple of days, but I heard the tires squeak, got my but out from under it about the time it rolled down.
View attachment 1715141382 Recently made a set of four car stands with removable ramps. Being removable allows for more room for a creeper or such , once the car is on them.
Yote
look closer , I don`t think the extras are needed. they have the angled braces in the center. I bought a pair of the plastic ones, and put a piece of 1/2 rubber under them, full length and width, that the front tires roll up on , before contacting the ramp. They would just slide on my garage floor w/o them.Those are 100% better than I could ever make.......however, if I may, I have a suggestion. Of course, yours would be straight. LOL But the red lines indicate my suggestions. On both sides and each end. I think the reason is obvious once you look at it.
AH SO, See it now.I saw those, but they are side to side, not fore and aft. If someone were to pull up and suddenly hit the brakes, they could collapse.
