nm9stheham
If you can weld, it is not all that hard to weld up a frame and put a couple of heavy duty chipper trailer axles (like Asplundh uses) under it from the scrapyard that come with electric brakes and springs . The axles need to be cut and extended a couple feet for car trailer width. If you get the steel from the scrapyard too, you can do this for $500-600. The 2 tricks are to provide some sort of bracing on the sides and some rigidity on the diagonals to prevent twisting. The intermediate laterals can be pretty light. Overall, you can end up with a ligth trailer for occasional use, and you can source all of the axle parts new ofr repairs. I have no clue for the PA process for titling a home-built traier though.
I'll add my vote for the Tekonsha electric brake controllers; the dual adjustments are there for both angle (sets when the brakes attack) and for gain (the braking intensity). This compensates for the hardness of towing vehicle braking, and for up/down slope of the road (more braking downhill). It also has a 1/2 to 3/4 second brake application delay that avoids transient trailer braking that can jerk on the hitch. I've had 3 of these and they all worked great out of the box.
