BJDEALER
I start up the car and it idles kinda rough. I let it warm up and then put it into gear and it dies. It will idle all day long but will die when put in gear. The only way i can keep it running is give it a lot of gas and peel out when i put it drive. The engine still sputters even then. I have a rebuilt 360 with a holley 4 barrel carb and electronic ignition. The engine was running fine one day and then this started. If you need more info just ask. Thanks
