I'd love a little advice. I've been having carb issues with my family heirloom '65 Mustang since I went through the engine three years ago. I've been driving this car for over 20 years, and have five carbed cars, and the other ones give me few problems, so I'm not a complete rube (I hope).
The engine is a 289, 9:1 compression (heads have been cc'd and I checked deck height), Comp 252H (206 @.050), Weiand Street Warrior intake, 16* initial, 37* total at 3000, 8* vacuum advance. I run a Pertronix Ignitor I with a full 12 volts and a Pertronix coil. I've run points in the past.
I have an Edelbrock 1406 on there right now that came on my Skylark and I've got tuned in well. It has two problems: so-so mileage (13 mixed, 17 full highway), and it picks up a slight surge if I am out on the road for over an hour or so (which is really weird).
I have tried a load of carbs on it, and they've all had problems worse than the Edelbrock (by far). The Edelbrock runs great except for what I've mentioned.
1. Summit 600...this was actually on the used 302 I bought initially that ended up smoking from the breathers and smoking the front pistons after 300 miles. Buyer beware! The Summit had an internal leak that fouled four plugs (one venturi obviously). I warrantied that one.
2. Pony Carbs Autolite 4100. Ran fine but I had to jet it up four sizes, and that carb was the one on the car when the used engine blew, so I sold it, which was stupid.
When I redid the 289, I put on my 1406, which was collecting dust in the garage.
3. New Holley 1850. I hit the gas and every time it would backfire through the carb. Holley's tech line seemed baffled because nothing I tried worked. I warrantied that one.
Back to the Edelbrock.
3. Quick Fuel Slayer 600. Lots of power, but idled rich and had a lean surge on the transitions. I probably could have tuned that out but I sold it because it was probably too much for a little 289 anyway. I was running as little as 1/4 turn out on the idle screws, so it needed smaller IFRs, but then I may have even leaner slow cruising.
4. I just bought a used Holley 390, installed a new baseplate (the old shafts were very loose), installed it. Idled great. Huge lean bog on acceleration (goes straight to 22.4 on the AF meter), won't get out of its own way, 15:1 AFR on full throttle. To be fair, this carb may be junk. It has what looks like a parting line horizontally across the middle of the primary side of the main body,like someone dropped it or something. I don't even know where I'd start to fix this.
Floats are adjusted, fuel pressure is about 4.5 psi (stock pump).
I'd like to drive this thing long distances without that annoying slight surge, but with the vast array of carb choices and my ADD/OCD tendencies, I would just like to talk out what to do next... Sorry to be so wordy. It's no hurry, because that old Edelbrock keeps plugging along most of the time, which is why I'm so frustrated now. Maybe I should just learn to love the surge.
I just realized I sound like an absolute carburetor idiot here. I swear I'm not; maybe this car is cursed or something! Maybe I'm just not persistent enough. Maybe I need to just buy Edelbrocks.
