Hyper_pak
Old School Chrysler Fan
So I will just say this should be a good discussion topic!
My Colt has a serious nose down attitude.
I have to run a lower float level with the carb tilt.
Can't change it right now, I will need a strut front end to get it up some.
In the mean time I measured about an 8 degree angle on my carb to get close to level.
I purchased a 3/8 solid aluminum spacer from Summit and took it to my machinist.
He said he would run the math and see what he could do.
I have since gotten some help with the formula.
Well with a 3/8 spacer, you can't do 8 deg, it turns into a knife edge around 5 inches across.
The spacer is around 6 something across.
I went on epay and found a 5 deg Moroso spacer so I picked that up.
The kicker in this is my carb faces the valve cover, not toward the front.
You can find lots of angle spacers for that orientation, not so much for "sideways".
This Moroso spacer is for a Roundy round car so it's the way I need it.
See the pictures for an idea of what I am talking about.
My manifold has a slight tilt forward anyway.
More in the next post.
