Furious65
C-body Guy
It appears he has put out a vid addressing some of the critiques and concerns people have about his carb cheater. I think he has some valid points.
Thanks. You just told me enough for me to know that he doesn't have a clue.I don't hate the idea of the thing... but it's not for me. that video though is not a good endorsement. His rant about not having a digital gauge was insane and just weird... also you don't have to stare at the thing all the time.. put it somewhere you don't see it and pull it out when needed.. it was just odd all around
Well, the power valve is for enrichment of the power circuit. Hence its name. WHEN do you want that enrichment? Holley says cut the idle vacuum in half and choose the closest valve to that half vacuum reading. Why would you want enrichment to the power circuit at such a low vacuum? It's the power circuit. I get a vacuum gauge connected to manifold vacuum with a hose long enough to get the gauge inside so I or my passenger can read it at cruise speed. I get the cruise vacuum reading. In other words highway speed with barely enough gas to keep it t speed. The vacuum reading will be highest then. I take "whatever" that reading is, and choose a power valve a couple of numbers lower. That way, the power valve is actually opening when it's time for power circuit enrichment. When you get it about right, you can feel when the power valve opens. After tons of reading on forums and magazines and such, I tried experimenting with it and I found that that's the way that seems to work best for ME. You will also be able to drop the main primary jet sizes down some, since the power valve is now opening during cruise enrichment and that can even pick the mileage up some.So, half of the idle vacuum isn't correct?
Yes it is..... that's why it's such a glowing endorsementIsn't that the same guy that put a weedeater carburetor on a car engine?
I wasn't makin fun of him......that project actually worked much to my surprise and probably to a lot of other peoples surprise too. lolYes it is..... that's why it's such a glowing endorsement
It's ok... i'll make fun he's actually a decent guy.. i had a friend that did like a dirtbike carb on a car in the 80s trying to get amazing milage... he also ran a fuel regulator crazy low... like that mattered.. people do weird thingsI wasn't makin fun of him......that project actually worked much to my surprise and probably to a lot of other peoples surprise too. lol
This is the better way to approach it for sure.Well, the power valve is for enrichment of the power circuit. Hence its name. WHEN do you want that enrichment? Holley says cut the idle vacuum in half and chose the closest valve to that half vacuum reading. Why would you want enrichment to the power circuit at such a low vacuum? It's the power circuit. I get a vacuum gauge connected to manifold vacuum with a hose long enough to get the gauge inside so I or my passenger can read it at cruise speed. I get the cruise vacuum reading. In other words highway speed with barely enough gas to keep it t speed. The vacuum reading will be highest then. I take "whatever" that reading is, and choose a power valve a couple of numbers lower. That way, the power valve is actually opening when it's time for power circuit enrichment. When you get it about right, you can feel when the power valve opens. After tons of reading on forums and magazines and such, I tried experimenting with it and I found that that's the way that seems to work best for ME. You will also be able to drop the main primary jet sizes down some, since the power valve is now opening during cruise enrichment and that can even pick the mileage up some.
I can give you one of the best examples of that. Doug Dutra. Were it not for him doing "weird things", we'd not know a lot about the slant 6 that we know today.It's ok... i'll make fun he's actually a decent guy.. i had a friend that did like a dirtbike carb on a car in the 80s trying to get amazing milage... he also ran a fuel regulator crazy low... like that mattered.. people do weird things
Thanks gents. I wanted to ask for Rusty's method earlier, but I didn't want to muddy the OP's thread. I'll study up a little more in detail, but the car in question that I'll be testing this on has several other issues that need attention before getting to the power valve.This is the better way to approach it for sure.
At least for us mortals.
One step fancier, but not exotic (ie. 5 gas analyzer combined with a load dyno) is datalogging MAP and acceleration.
Every decrease in vacuum with more throttle should result in more power.
I've posted a couple of snapshots where I did that.
Here's one, which does not make it to the enrichment point in part because too much timing.
Its difficult to "crowd" a vacuum long enoguh to get good readings. Better way would be on a closed course, starting from the same speed each time.
We've also discussed the theory a few times here.
[/URL]
I apologize if I did that, but I was thinking it was kinda all related so I threw it out there. If it's too far off the beaten path, just ignore it. LOLThanks gents. I wanted to ask for Rusty's method earlier, but I didn't want to muddy the OP's thread. I'll study up a little more in detail, but the car in question that I'll be testing this on has several other issues that need attention before getting to the power valve.
