Carb gasket/spacer for 7576 air gap manifold
MOPARMIKE55
I/J CM
Rochester, NY
I am running a 360 cid in Crate motor Class. I just installed an Edelbrock 7576 air gap manifold. I was using an open spacer/gasket on my old manifold. Do I need to change because of the dual plain separation? Thanks,
Mopar Mike
I am running a 4 hole 1" phenolic spacer on my air gap with a eddy carb, works fine for me, you will get varing opinions on this.
I just found the threads about the spacers from a few years back. I wasn't sure if the HVH 1" is still the best option. What type are you running? Thanks,
Mike
My 340 has a Torker and it also has the 1" spacer. Revs out well to 6300, maybe more.
If I get an air gap should ai put the spacer on also?
What type are you running? Thanks, Mike Edlebrock spacer
If I get an air gap should ai put the spacer on also? Depends, I have one on mine works good for me, try it with and without, thats the only way you'll know.
