Maybe it's so cal gas or Colorado gas but I have never had the problem.
Will a Vapor Return cause a Loss of Fuel Pressure to the Carb from a Mechanical Pump?In 50 years I never had it happen until last summer. Hot day, AC on, when I shut the engine off it sounded like popcorn popping under the hood. Lousy gas is certainly a contributor. A Edelbrock insulator gasket was available at the local AutoZone. That seems to have quick fixed it, but a comprehensive solution would also include blocking manifold heat and installing a vapor return.
If it's too big it can. I've read about folks putting restrictors in the return line to keep the pressure from falling too much.Will a Vapor Return cause a Loss of Fuel Pressure to the Carb from a Mechanical Pump?
He said vapor return, not fuel return. Vapor return cannot cause a drop in fuel pressure. All it does is vent the float bowl. Now a solid fuel return is a different story. But properly set up using the fuel pressure regulator as the return orifice, the pressure won't drop, as long as there's enough pump for it. In my case though, there's not an HP mechanical pump for the slant 6 that I know of, so if I run a good return system, I'll have to go electric......which I despise. lolIf it's too big it can. I've read about folks putting restrictors in the return line to keep the pressure from falling too much.
But this ain't about "you" and "your engine". Let that sink in.I'm in Manitoba Canada at about the 50th parallel, at ~930ft elevation, and the hottest days of summer here, rarely get past the mid-90s, but most days in July, are in the mid- Eighties.
>My engine has been running just fine on 87E10, since 1999.
Ok sure, after a week of sitting, the leaky front pump has partially drained the front bowl. Sometimes I prefil the front bowl, and Sometimes I get lazy and just stomp the double-pumper a couple of times.
>After she's warm, on any restart, she'll usually fire up on the first revolution, often on the first or second cylinder that comes up.
Well, to be honest,
>I have a couple of secret weapons, namely; 180psi plus CCP, a 750DP on an AirGap, fresh cool air from above the hood, a well-synced transfer slot, and a shady North-side carport, that stays relatively cool.
>The thing is this; fresh 87E10 begs to lite off. At 80*F, the VOCS are anxious for a spark. After a week in a vented fuel tank..... not so much..... unless it's been "stabil"-ized, lol.
I've been running that cheap skunk-pee since 1999, and everything on my yard has been tuned to run on it, cuz it's the only gas sold in my town.
>Op is in Florida; what's the elevation there?, and how hot does it get ?
Wiki says the highest point is 345ft and and the summer temps are maybe a tad higher there as here, namely upper 80s. Thus my engine would be right at home in Florida.
I understand that some of you guys have trouble with percolation down there; I get it.
And I get that the gas companies have reformulated their fuels for EFI closed systems, which can create starting issues for carbed engines; I get that too.
What I don't get, is your aversion towards alcoholized gas, when it clearly is a winning recipe, when you work within it's limits. Sooner or later it's gonna be all you can get, so you might as well tune for it now.
I watched a video recently where a lady showed how many gas pumps use the same pump lines for the filler hose. If a guy fills his car with regular ethanol 87 and another guy comes after him and fills his 1 gallon gas can with non-ethanol 91; he will likely get 1/2 to 3/4 gallon of the E87 because the lines are still full of the old stuff. Only pumps with dedicated nozzle for non-ethanol would be exempt from this. Was an enlightening video.You "think" you run non ethanol. I've done some testing on it around here and there's still some in it.
Then pedal to the floor and crank.
I have never in 30 years of driving carborated cars had that problem.
How did our parents ever drive these cars daily 50 years ago. It must have been miserable
How do you test it?You "think" you run non ethanol. I've done some testing on it around here and there's still some in it.
How do you test it?
How do you test it?
A hygrometer measures moisture in the air. I could see Rusty using that to test. Hydrometer may be?I think you can buy small kits to test it or you buy a hygrometer and use that.
It’s a PITA to do it at the station. Easier to do at home.
YepLousy gas is certainly a contributor.
It depends where you live. Filling stations selling E-0 are all around me here on the southern shore of Lake Ontario. There are more now than anytime in the last 15+ years, with more stations taking it on all the time. Many have dedicated systems with separate tanks, plumbing, pumps and hoses. Before this, I used Stabil Marine.What I don't get, is your aversion towards alcoholized gas, when it clearly is a winning recipe, when you work within it's limits. Sooner or later it's gonna be all you can get, so you might as well tune for it now.
Pour some in a glass and let it sit a day or so. Anything "not" gas will separate. Ethanol is lighter than gas and ends up at the top. You can really smell it when it separates. Based on what I've seen in a glass like that, I'd estimate probably 2 or 3% in the supposed "non" ethanol gas around here. I know it's not scientific, but that's the only way "I" can do it.How do you test it?
You can do that. You can also use an old optical anti freeze tester. When was the last time you saw one of those?A hygrometer measures moisture in the air. I could see Rusty using that to test. Hydrometer may be?
That's a big problem too! We're gettin fleeced, there's no doubt about it!I watched a video recently where a lady showed how many gas pumps use the same pump lines for the filler hose. If a guy fills his car with regular ethanol 87 and another guy comes after him and fills his 1 gallon gas can with non-ethanol 91; he will likely get 1/2 to 3/4 gallon of the E87 because the lines are still full of the old stuff. Only pumps with dedicated nozzle for non-ethanol would be exempt from this. Was an enlightening video.
It probably wouldn't hurt!How to test the alcohol content of gasoline
Here’s a safe, fast and easy way to check the alcohol content of gasoline using a graduated cylinder.www.delphiautoparts.com
I have a few hydrometers and a couple refractometers. I need to do some testing I see.
[/URL]
It's all ethanol.LOL…when I bought my hydrometer I’m pretty sure it said you can’t use the ones for drinking alcohol on non drinking alcohol…just sayin…don’t mix up your fuel and your booze.
