My old 85 Ram had a factory roachester lol Q-jet. That truck was a factory slug.
Gee, I put a lo-compression 318 in my 84 with a TQ on it and with 3.55s she spun 28s for a loooooog way. not bad with 3.23s either.My old 85 Ram had a factory roachester lol Q-jet. That truck was a factory slug.
Somewhere around the mid ‘80’s, QJ’s are round a good bit. Exactly when, IDK. But that did become the replacement carb for the TQ at one point.First off let me say that it's highly possible that I may not have looked in the right place but I didn't find any information on a q jet being used or available for a sbm
I’m not a 100% positive on anything on that topic. What I do know is Carter was making QJ’s for Rochester for a while. I never head of a TQ shortage but I did notice both were available or used at the same time towards the end of Carters run as a biz.I heard
that the QJ on the Mopes was due to a TQ availability crises, back in the day. It sorted itself out soon enough and TQs retook their rightful place.
My son has an 85 Dodge Truck with a 360 that came from the factory with a QJ. Think QJ's were cheap and Ma Mopar was savin' a few bucko's.QJ is a spreadbore like the TQ. Same bolt pattern. You need to check fitment to the intake to make sure all the passages in the carb base are covered & that linkages do not foul etc....
I've been out of the car scene for a while now so I don't even know if there's any salvage yards in Missouri like they once were. I did do a little research on spreadbore carburetors and I think that the holley 650 was the only spreadbore carburetor available. Does edelbrock even offer a spreadbore carburetor? Unfortunately I'm not real good with carburetor tunning so I would need one that doesn't need constant tunning. I have done some research on carburetors and from what I've read the spreadbore gives the best throttle response and driveability. You guys have said that the Thermoquad can be tuned for a 318, is that changing of the jets? Sorry I didn't mean to highjack the op threadSomewhere around the mid ‘80’s, QJ’s are round a good bit. Exactly when, IDK. But that did become the replacement carb for the TQ at one point.
Carter officially folded up in ‘84? IDK for sure. I forget.
From there (or approximately from then on) QJ’s were on top of the MoPars.
Up till 1989, all of my vehicles were used, mostly from the 70's so I don't have any idea of what carburetors were available on the mopars. I didn't even know that they have Q-jet on them until todayMy son has an 85 Dodge Truck with a 360 that came from the factory with a QJ. Think QJ's were cheap and Ma Mopar was savin' a few bucko's.
I just did a quick search for a TQ Carburetor and they go anywhere from $400 - almost $2100Dan,
If you can find a TQ.......just run it. I could never work out why a 440 with a TQ [ #6410 ] had .125" sec jets but a #6454 used on a 360 had .143"sec jets.
Jet size is NOT related to engine size.
If you use a TQ on a 318, you may have to change jet sizes &/or met rods. What you will have is great throttle response, mileage & power.
I'm really surprised that more of you guys didn't mention the tried and true thermoquad. The 340's came from the factory with them, guys have said how easy they are to tune and how much better they are for throttle response and yet the thermoquad was only mentioned a couple of times. A edelbrock performer rpm and a thermoquad carburetor and your good to go. Is this bad choice?
Oh man you opened up a can of worms! LMAO.
AJ is right on carb size working from little to big. Considering the build, I’ll also assume a decent gear ratio is back there for the go fast effect.
I can only say what I would do and having used a 600 AFB to a 750, I liked the 750 a little better. Even on the lower rpm side of just around town or initial take off, there was a better and more powerful feel from the gas pedal. Of course, everything will be the state of tune.
If you don’t have a preference of intakes, I would use the RPM. I’ve had both intakes, so there’s that behind my choice. Nether is bad and nether is worth getting rid of for the other. Since you have both, try it for yourself and decide.
Some will run the LD-340 because it’s a ”Day 2” hot rod part and others will run the rpm without care or concern of that period correct hot rod part.
So far my favorite combo was the MP tips modified LD-340 and the big TQ.
Yeah I should’ve expected a conglomerate of answers it’s kind of like asking people what’s the best cam which is super subjective. And yes it’s going to have a decent gear ratio on it I have a set of 3.91s on the side. And a day 2 build is exactly what I’m looking to do all parts I have for the most part are about mid to late 70s. I just have a major appreciation for people that keep their cars to the time period but of course there’s nothing wrong with taking advantage of modern tech. I want to run the LD but my issue is the plenum divider being completely removed and ported a ton for a race application and I’m not sure if that’ll affect how drivable it is. Also an update on the carb I got a Holley 750 DP from my dad as he’s going to a fitech system for his car. I appreciate everyone’s input thank youOh man you opened up a can of worms! LMAO.
performer rpm is a square bore, which means you'd have to run a spacer/adapter. also no choke well. so if you wanted to run a TQ you'd need to find a superquad, electric choke conversion parts if those exist, or rig up a manual choke.A edelbrock performer rpm and a thermoquad carburetor and your good to go. Is this bad choice?
No conversion parts available.performer rpm is a square bore, which means you'd have to run a spacer/adapter. also no choke well. so if you wanted to run a TQ you'd need to find a superquad, electric choke conversion parts if those exist, or rig up a manual choke.
aftermarket dual plane spread bore options are: performer, weiand 8007, or offy 5685.
Better options! I agree.if you like tuning carbs, TQ's are great. if you want to put something on and not have to fuss with it there's better options. options that involve not hunting down parts and paying thru the nose for them.
thanks for the addition, it's been awhile since i've held one so i'd forgotten about the lack of thoseThe Weiand's have no choke well.(Or coil mount bosses)
Just an interesting FYI:performer rpm is a square bore, which means you'd have to run a spacer/adapter. also no choke well. so if you wanted to run a TQ you'd need to find a superquad, electric choke conversion parts if those exist, or rig up a manual choke.
oh wow, that's neat!Just an interesting FYI:
Electric Choke Conversion Kit - TQ
I did see that TQ's can be found and they start around $450 to as much as $2100.oh wow, that's neat!
i figured something like that existed, or you could cobble something together that was workable.
however, this new information does not color my thoughts on the TQ
are you for real?I did see that TQ's can be found and they start around $450 to as much as $2100.
A big huge thank you!Just an interesting FYI:
$450? Pro rebuilt, awesome looking.I did see that TQ's can be found and they start around $450 to as much as $2100.
At $450, going by the photos they looked great. $2100, like you saidA big huge thank you!
I love being proven wrong with the added bonus of possibly getting one.
THANK YOU!!!!!
$2100 = Crack head pricing.
