greymouser7
Vagrant Vagabond “Veni Vidi Vici”
- Joined
- Apr 17, 2010
- Messages
- 3,729
- Reaction score
- 1,457
i was watching a porting video on YouTube and they mentioned carbon buildup.
I look it up on the web and most references relate to the problems created by direct injection-which I understand.
1. How bad is it?
Is this correct: “You might already be aware that an additional heat buildup of just 30° to 40°F from excessive combustionchamber carbon deposits can cause preignition, resulting in a reduction in fuel economy,”
2. Does it get everywhere? In and around the top ring? Around the valve seal?
Valve seat? Valve guide?
3. Is this not a problem due to other parts of the engine wearing out prior to significant buildup? (not a concern except for racers??)
4. They used to talk about the parrafin in AV gas creating significant carbon build up and aviation combustion engines are subject to 3,000 hour rebuilds unless home built.
5. Does a polished combustion chamber reduce this problem?
6. More likely to occur on iron or aluminum heads/cheap gas or ethanol free fuel??
Extremely curious, thanks for your time!!
1. How bad is it?
