Map63Vette
If you run with a carb that should do it for the engine side of things. Not sure about the trans though. You'll probably need some sort of kickdown linkage, but if you run a carb I think you can use a stock one from what I've heard. You'll also need to wire in an electric fuel pump since the hemi has no provision for a mechanical.
