MLC Dodge
Installed a reman carb and the 74 Duster runs good again. However, on first start up, it revs real high until I kick the throttle, then it comes back down to idle. How do I adjust the fast idle setting?
It is The choke that you need to adjust. But it sounds like its doing it's job. When you start the motor while it's cold, the choke will remain closed and the idle will be high until the engine is warm. Wait. Do you have an electric choke or a manual choke? This makes a difference. From what you're describing it sounds like you have an electric choke. There is nothIng wrong with you carburetor. It is just trying to keep you motor from stalling out while it warms up. My Holley 390 cfm electric choke carburetor dOes the same thing. It's brand new.
There's a screw on the bottom right of the carburetor. That is your idle screw. Right turn is higher rpm left is to decrease the curb idle.
Johnny dart, all you have to do is answer the guys question. If you know the answer, then answer it! No need to be an ***. Maybe you weren't raised by decent folks, but where I come from that's called rude.
