danielb927
I got a new carb and installed it today, its a Holley 670 cfm Street Avenger. I got the dual-feed from Holley, part number 34-150 I think, and it leaks pretty badly. Most of it is out of the back line, the secondaries. I read somewhere that this dual feed is prone to leaking, is there anything I can do without having a machine shop around to re-do the flares, or should I just get a summit kit or use the rubber ones that came with the car?
By the way, let me throw in a recommendation for HeliCoil kits and McMaster-Carr, where I bought mine. Took all of 10 minutes to fix the stripped hole in my intake manifold once I got the right drill bit, and it only would have been easier if I had actually had a tap handle. McMaster got it to me one day after I had ordered it the night before at like 6 p.m. It was a little pricey but I understand the Helicoil kits usually are.
