Lenni
Member
After I start my 62 Lancer gasoline begins to spew out of the Bowl Vent Valve / Accelerator Pump Plunger. (WHY?)
Agreed with all
Thanks for the help. I removed the needle, cleaned it and the seat + all around the floats, installed a new accelerator pump and fuel filter. Put it back together, runs pretty good and no fuel leaks.Stuck float needle valve, junk between needle and seat.
Thanks for the help! No more fuel leak.Stuck float needle valve, junk between needle and seat.
Thanks for the help. Cleaned it all out, installed a new accelerator pump and fuel filter. Runs pretty good, no more fuel leak.Yep, junk between needle and seat, a bad float, or too much fuel pressure.
Rust from the tank can cause the first issue.
Brass floats can leak and fill with gas causing the issue.
Too much fuel pressure from a new fuel pump if installed lately.
Well good! That's a fine lookin car!Thanks for the help. I removed the needle, cleaned it and the seat + all around the floats, installed a new accelerator pump and fuel filter. Put it back together, runs pretty good and no fuel leaks.
John 14:6Well good! That's a fine lookin car!
Baden Pa.Nice car.
Pixburgh here too
