Carburetors for STR-12 Manifold
DC 340
Virginia
I am building an Edelbrock STR-12 manifold intake system here:
Wanting new carburetors for the thing. I'll be working fuel line and linkage for the rest of my life LOL. I am seriously looking at the Edelbrock VRS-4150 series, #1306 (650 cfm). I need two. Any advice? A link:
Thanks.
Impossible to help you without knowing about your engine size and how built your or stock it is. Streetcar? race car? Or both?
Street, S/S, 600-650 cfm
Race, 750 cfm
Manufacturer, model and style, your call.
I've heard stories of the lid breaking from backfires. I would research that. I have seen new linkage in reproduction but I don't remember where. Beautiful setup, I will follow your progress.
I’ve seen home built spring assisted backfire relief valves built for them before. Modifying one to outfit it with a burst panel or supercharger backfire relief with light springs probably isn’t a bad idea.
Uh, doesn't this really depend on the engine build?
Yes it does, I agree. I have a few engines it may go on. My 389 c.i. 340 stroker is what I was thinking. But really, just wanting to build a versatile small block setup. The VRS-4150 has all the vacuum ports/PCV ports for street which is important to me.
Maybe something in the Holley Brawler series could fit the bill at a lower cost? Looks like they have some that are street oriented and still have a lot of adjustability with bleeds and such. My main thought is whatever you choose, you have to get the pump shot right for that large plenum. Oh, and i do think the 650 is right in the ballpark for anything with that manifold over 340''.
there's a lot going on there in the "good" column: 4 corner idle, pcv/vacuum provisions, down leg boosters, fuel inlets, float level windows, tuning parts, but i guess the question is if you want to run dual double pumpers on something that's not a race car?
Normally, yes, this is why I answered what I did.
Here is food for thought. If 318 will run can put 2, 600 Edelbrocks on a in line dual quad on top of a 318…… I’m sure a 340 will handle it just fine. I’m also sure, a stroker 340 to say, 420_ish area will do just fine.
If I was racing with this intake and it’s a 340 to a 434, it would be twin 750’s.
I've been running this on the street for 15 years now (340+.030). I'd be glad to correspond with you about an STR-12 on the street. It is set up with 2 500 Edelbrock performers (AFB), but I think if I were replacing them today I'd use 500cfm AVS2s. I'll send you a PM. My original lid was cracked and repaired twice but someone put me on to a fix that I can share that resulted in my never having the backfire issue. I can also send detailed pics of fuel lines and linkage. Right now my manifold is off (for the first time in 15 years) for pushrod replacement, so it's a good time to ask questions and request pictures as I reassemble it over the next week.
If somebody wants to really hog wild with one of these, mine came with a lid to mount a BDS blower on it that I am very sure I will never use!!!
I install two spring loaded burst plates on my bigger manifolds (tunnel ram, big single plane etc). The need to be adequately sized unlike some of the postage stamp sized units contained in a spacer.
If it was me I would be running something with annular boosters and a relatively lean transition/cruise AFR and a tad rich idle AFR. It seems to help .
Not a fan of the Brawler carbs OOTB.
Pay attention to that last sentence. Brawlers out of the box are stupid fat. They need work. A lot of work.
Cool! That would be a big decision though to mount. Your post lead me to this:
That might work well without manifold mod but expensive X 2 for me. But it is a money pit I am working on. I understand. Thinking... In the spirit of money pit, I am still leaning towards the Edelbrock VRS-4150 as I want to try something different.
CFE used to make a similar model as this one:
This size works well, especially one on each side of the plenum on a t-ram.
That said, many people have run large plenum manifolds and done nothing. I like safety precautions that protect my equipment so a few hundo seems reasonable.
The whole point of the STR manifolds was to get the runner length of a tunnel ram, under the hood (STR = Street Tunnel Ram) In my Dart I couldn't put any carb spacer in and it was a struggle to find an air cleaner with enough perimeter length to use a filter element that was only about an inch tall and still have enough filter surface. That blow off plate that goes under the carb wouldn't fit for sure! There's plenty of room for the spring loaded nitrous plates, though...
[/URL]
Thanks.
New street build and new carbs. For dual 4 barrel, Edelbrock tunes the AVS2 500 carbs. That is what I would be looking at.
With the large plenum you will need a strong accelerator pump shot. You can use a number drill to increase the pump squirter ID to let more fuel out quicker.
I would be inclined to talk to Dan at The Carburetor Shop in Minnesota. They can probably modify the accelerator pump shots to what you need.
Thanks all for your input. This is what I already did. : ) I ordered two Edelbrock VRS-4150 series #1307 rated 750 cfm. The 750 comes with annular boosters as the 650 does not. I think they will work for me.
VRS-4150 Carburetor 750 CFM #1307
Will post pics when they get here.
