[WANTED] Cardboard Headliner
va58
Restoration Jedi
Smithfield,Va.
Rating - 0%
0   0   0
Searching for a Cardboard headliner for 72 Duster. Black would be the preferred color but would consider all colors. 5 or 6 hundred miles radius of east coast of Virginia would be desirable. Need I say it? Must be mint...
I am well aware of the repop's in plastic. They are far from correct..
Not sure what year they stopped putting them in cars? 75/76/?
I may have one here in Alberta VA 23821
Will check my cars tomorrow..
Got arond 7 70-73 dusters
Justin
Thanks Justin. May need a few pieces of metal if you have a car or two that you are cutting up. driver's side door jamb dogleg. the last couple of inches above the curve and a few inches below the sean into the drivers rocker. my parts car is rusty in the same place as my restoration project.
This should help
This should help
I know for a fact I have that off a 73 dart sport and a 73 duster.
They should work. Let me know what you think if they will work?
Also I will let you know on the head liner. Not positive if I have it may be not mint not sure will check my cars though.
Justin
Rarer than a "M" code car? Are my chances of getting a date with a supermodel better?
