The early A body cars like the 66 he is working on actually have both sill plates as well as carpet hold downs.They're called sill plates. It may help with the search.
Looking for the
aluminum carpet hold down trim for both doors and the extensions to the rear panels for a 66 barracuda
Is this for me or the OP?Pictures pictures pictures
PLEASE!
The OP.Is this for me or the OP?
You are correct I have the sill plates , I am looking for the carpet hold downs that go over the lower door weather stripping and also hold down the carpet , there are also two smaller extension pieces that are beside the rear seat and under the rear panels that hold the carpet down.The early A body cars like the 66 he is working on actually have both side plates as well as carpet hold downs.
So, question to the OP, which pieces do you need?
Thanks for the help . As Cosgig said there are also carpet hold downs on the early a bodies .They're called sill plates. It may help with the search.
Great . Any pictures would help to make sure we're talking about the same parts . ThanksI have the sill plates for the doors but not the inner pieces that hold down the carpet. I do have the rear extension pieces though.
Thanks for your helpLaysons are a one piece replacement. I cut them like the original and reused the the rear pieces
Thanks Rick .Currently out-of-stock on those carpet hold downs.....
Thanks for your helpReproductions used to be available. Layson's maybe?
Sorry I don't have any parts to take pictures of.Pictures pictures pictures
PLEASE!
