bad440
everything,all the time..
installed super six intake,and carter carb originally on a 318.runs a whole lot better than the one barrel ever did.only thing is it idles a little high.there is a small hole in each butterfly like you would drill in a holley for more air with a radical cam.if i fill those do you think it will slow the idle?it only needs to come down about 100 rpm.
