csx452
Did Carter make a 750 carb for the 340? If so, what was the model number?
Thanks,
Frank
Thanks,
Frank
I don't beileve so, I beileve they all got the 630 AFB/AVS carbs.
Are you looking for a 750 AVS?
Manual or auto?
Weren`t the 440 AVS`s 725 or 750cfm? One of the first mods a lot of guys would do to their 68/69 340`s was to swap out the 340 AVS for a 440 AVS.
I'm sure 440hp engines were 750's. Not sure about the std. 440's. You can identify them real easy cause the 750's had all 4 barrels the same size where the smaller carb has smaller primaries.
their were all kinds of numbers, i think they were rated 625 & 725cfm but the actual flow was a bit lower more like a real world 570 & 675 cfm, some 440's had the smaller primary so they would be the 625 cfm. http://www.mopar1.us/moparcarblist.html
