[SOLD] Carter AFB from 1967 Barracuda Charger w/ Manual and others
fourstrokin
Member
Bozeman, MT
Rating - 0%
0   0   0
I have a Carter AFB part number 4298s (525 CFM) that is currently installed and in good running shape on my 383. Searches I make show it as a Barracuda setup, I would assume some others too (another place showed 64-67 383, 426, 440)? I have it installed in an automatic (1950 Dodge Coronet) so I modified the throttle arm to accept my kickdown as well as match the throttle travel of my 1950 pedal assy (unfortunately...). So if you are looking for a restoration carb, that would need to be modified back. I also converted it to a manual choke but do still have the vacuum solenoid that was on the OEM choke setup (and pretty sure I have the rest of the choke linkage stuff I pulled off). I have a brand new rebuild kit for it as well that is included. It is in good running shape as it sits but I would assume it would benefit from a rebuild and cleaning. I'll ship for free to the lower 48 states. $170
4298-s
