fourstrokin
Member
I have a Carter AFB part number 4298s (525 CFM) that is currently installed and in good running shape on my 383. Searches I make show it as a Barracuda setup, I would assume some others too (another place showed 64-67 383, 426, 440)? I have it installed in an automatic (1950 Dodge Coronet) so I modified the throttle arm to accept my kickdown as well as match the throttle travel of my 1950 pedal assy (unfortunately...). So if you are looking for a restoration carb, that would need to be modified back. I also converted it to a manual choke but do still have the vacuum solenoid that was on the OEM choke setup (and pretty sure I have the rest of the choke linkage stuff I pulled off). It is in good running shape as it sits but it would probably benefit from a rebuild and cleaning. Just the carb, does not include air cleaner, cables or any of the attached extras. I'll ship for free to the lower 48 states.
$90
$90
