Looks like a 9636. It also looks like the pump piston is fairly high up in the carb body. If it is raised too high the pump piston will be above the slot in the carb body and it will not be able to develop pressure. You want the pump to just bottom out at WOT, but that's it. You can delay the pump shot if it's too high.
So, look at the squirters as you cycle the throttle by hand. The pump should begin discharging immediately. If they do, try going up 2 numbers on the main jet, stiffer springs, etc. If they don't start squirting immediately, make the link rod as long as possible (flatten the bend) without the pump bottoming out.
Keep in mind too much pump shot can also cause a stumble.
