Cast iron exhaust manifold cleaning
ajarofclay
Frankfort, Illinois
More of a "how to" question; I'm wondering what are some of the better ways to clean up and coat or treat factory stock exhaust manifolds. As Always, thanks in advance, Gentlemen...and/or ladies.
I media blasted mine and then coated with POR15 high temp paint. It looks pretty good to me.
POR15 as mentioned....manifold gray
Once blasted, wipe with brake/component cleaner, then brush on with POR15 Manifold grey. That stuff goes far, is durable and can be touched up with brush. It has the consistency of thin toothpaste, but coverage is above excellent. A small can will do 5 sets, 2 coats each of sb manifolds easy.
POR-15 High Temperature Paint - Gray - 8 fl. Oz. - High Heat Resistant Paint - Withstands Temperatures of 1200 Degree F | Weather & Moisture Resistant https://www.amazon.ca/dp/B00J6B1JZY?tag=fabo03-20
Crushed glass media blast, VHT Cast Iron manifold paint... properly cured in an oven and Bob's your uncle. 6+ years on mine and about 4000 miles, still look good.
por15 coating. foam brushed it on.. cured it in the oven some even though you don't really need to..
