palousedust
This winter replaced tie rods, ball joints, upper and lower bushes, steering box, pitman arm, idler arm. Got it all together and took it in for alignment and they're having problems. Car tracks to the left and the shop says that the passenger side tire needs to be another 1/2 inch back to get it to the place for it can be aligned. I bought the car last summer as a project so really don't know the history of it. Don't think it has been in an accident. I've tried to address the problem with off set bushes. I discovered the ride height was way off because of settling of the suspension and corrected that so it is spot on now but haven't taken it back and according to my measurements it didn't seem to move the tire back. Front cam bolt is way out and back cam bolt for upper control arm is way in. I've loosened the k-member bolts and tried to get a little movement that way w/o luck. Switched tires around to see if that would make a difference but didn't. Car tracked fine before I took it apart. It just had the normal sloppiness of a front end that had never been rebuilt. Any other suggestions you can lob my way? Can a torsion bar in some way hang up the lower control arm from moving as far back as it should? Looking at it, it seems to me that if you have been able to get it back together it should not be an issue. But I'm only looking for a 1/2 inch somewhere.
