A833
Active Member
Can anyone give some advice regarding replacing the window felts on my 64 Valiant V200 sedan. Any help would be greatly appreciated. Especially with the rear windows that do not roll down all the way. Tips, pointers ect?
You need to to refurb since new felt won't fix the binding issue. Remove rear seat bottom, then rear door panels. You push aft on the seat lower frame at the 1/4 & 3/4 across locations to unhook from the floor, then wiggle out.... Any tips Chris on pulling out the rear glass?
Thanks
